Results 1 to 9 of 9
Thread: HTH 6-Way Test Kit
    May 2013
    Cyprus
    159
    HTH 6-Way Test Kit
    Hi all you across the pond
    Have anyone come across a HTH 6-Way Test Kit. These are being sold on E bay for 23 dollar and 17 dollar postage.
    Do you know if they are ok
    Thanks
    Living in Cyprus
    Still enjoying life
    38,415
    Re: HTH 6-Way Test Kit
    It lacks the FAS-DPD chlorine test which is needed for accurate FC and CC testing. Also there is not much of some of the reagents.
    The HTH 6-way is good enough to get a mention at the bottom of the article on recommended test kits here: pool-school/pool_test_kit_comparison. It doesn't get a full recommendation because it doesn't include the FAS-DPD chlorine test. If you can find that test separately, you're good to go.
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
    schertzy82's Avatar
    May 2012
    Peoria, IL
    100
    You can probably get the HTH 6-Way at Walmart for around the same price. Just make sure it's the 6-way drop test kit, not the 6-way strips.
    Intex 18ft x 52in Ultra Frame Pool, hard plumbed w/skimmer and fountain
    Intex 4000 gph cartridge filter pump
    Intex SWG
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by schertzy82
    He is overseas, so I don't believe Walmart is an option.
    Essential Links:
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    The HTH 6-way is a good starter kit, with actually two exceptions -- the aforementioned FAS-DPD not being included, and the TH (Total Hardness) instead of CH (Calcium Hardness). No calcium buffer for that test, as in the TF-100 or K-2006.
    All in all it would be a good value for you, if it can be shipped to your location. If you can find someone that is willing to ship the FAS and DPD reagents to you, you would have a close approximation to the Taylor or TF kits.
    schertzy82's Avatar
    May 2012
    Peoria, IL
    100
    Quote Originally Posted by Brushpup
    Oops, didn't see that. I guess "from across the pond" should have been my first clue. I'm thoroughly embarrassed now. My apologies, please disregard my earlier post.
    Intex SWG
    May 2013
    Cyprus
    159
    No problem
    Always glad of any support and it is information filled away for use at a later date.
    Thanks to you all
    Living in Cyprus
    Still enjoying life
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Like others have said the HTH 6 way drop test is not ideal, but can be functional in some situations where CYA is kept at fairly low levels (30-40 ppm), we generally only suggest it for people on a tight budget trying to maintain a small seasonal pool where they can dump the water if / when something goes wrong, as it does not provide any way to test elevated chlorine levels that are needed in the SLAM shocking process.
