Results 1 to 12 of 12
Thread: Received my TF-100 kit and these are the results.
    Merc Sof's Avatar
    Jun 2013
    Southern Alabama
    47
    Received the TF-100 kit and these are my results:
    Ph 7.5
    FC 1
    CC 20
    TA over 500
    CH over 1100
    CYA 90
    US Army Combat Veteran
    27,000 Gal Salt Water Pool
    Vinyl Liner
    Aqua-rite SWG
    Hayward pump and Sand filter
    Polaris pressure side pool cleaner with booster pump
    Mar 2010
    Spring, TX
    1,082
    Re: Received my TF-100 kit and these are the results.
    I think you may have your FC and CC mixed up.
    The one thing that sticks out to me unless that is an extra 0 in the CH level is that needs to come down right away.
    So lets make sure all your results above are correct especially in reference to CH, TA, CC, FC.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Merc Sof's Avatar
    Jun 2013
    Southern Alabama
    47
    IT started raining so when it clears I will test again and post. Thank you
    Vinyl Liner
    Aqua-rite SWG
    30,419
    What does your water look like? Testing in a bit of rain is fine....take the sample from a foot or so below the surface.
    Merc Sof's Avatar
    Jun 2013
    Southern Alabama
    47
    The water is a blue cloudy color. It was cleared up after algae, clearer than had ever been but there were many leaves in the bottom. Cleaned leaves out and clouded up a blue color instead of green and have been trying to get it cleared. Have used the shock method several times and no results. Can't even see to the bottom of the shallow end of the pool
    Vinyl Liner
    Aqua-rite SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Quote Originally Posted by Merc Sof
    You almost used the shock method. Without the FAS-DPD test kit, you probably weren't able to do an accurate overnight loss test or measure the CC level, and you stopped when only one of the three criteria were met. The algae is regrouping for a counterattack, hence cloudy.
    Merc Sof's Avatar
    Jun 2013
    Southern Alabama
    47
    Now PH is over 8.2
    FC 1
    CC 0
    TA used 25 drops and never turned red. Turned from a green color back to clear with no red at all.
    Calcium 250 25 drops and never really turned blue from pink....But had almost a slight blue tint.
    CYA 90
    Vinyl Liner
    Aqua-rite SWG
    Merc Sof's Avatar
    Jun 2013
    Southern Alabama
    47
    Why does my everyday chlorine tests show high chlorine but the drop test shows low?
    Vinyl Liner
    Aqua-rite SWG
    Richard320's Avatar
    Jan 2010
    18,995
    What's an everyday chlorine test? Strips? Your old tester? Your new OTO test?
    For this process, all you want to use is the FAS-DPD test. The powder. Use a 10 ml sample and track FC as 1.0 or 1.5 or 2.0 -using the decimal point - so people know it's from that test and not someone eyeballing shades of color. Also do the CC test.
    If FC is really high, the pH test will go weird. That's why we say set the pH at the beginning and forget it. accurate-ph-test-during-shock-levels-with-r-007-t61076.html
    If that 1 FC reading is accurate, then you're not following the shock process.
    Merc Sof's Avatar
    Jun 2013
    Southern Alabama
    47
    The everyday test is the blue kit K-1000 that comes with the TF-100. Before the TF-100 I used test strips because that is all I had. I shocked the pool using the bleach method I calculated from the volume of my pool and the cloudy blue color in my pool. I added over 20 bottles of 128 oz bleach in a few days and showed no real improvements.
    Vinyl Liner
    Aqua-rite SWG
    Jun 2012
    Howell, NJ
    977
    First you should lower the pH to around 7.2. Then you need to follow the shock process, until all 3 criteria are met. The process is linked to in my signature.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Merc Sof's Avatar
    Jun 2013
    Southern Alabama
    47
    PH 8.2
    FC 47
    CC 4
    TA 140
    CH 320
    CYA 90
    Vinyl Liner
    Aqua-rite SWG
