Can I correct low CYA and high ALK at same time
vanessadickson
70
Paris, Kentucky
Hi guys! In second year of Troublefree SWG pool and just getting balanced, from numbers below you see I have low CYA and high ALK. Want to add recommended amount of stabilizer and use acid process to lower Alk (reduce pH, aerate and repeat until ok) but just wondered whether I had to wait some time after adding liquid stabilizer before I did the acid pH/Alk thingy.
Thanks so much!
I have learned so much from you guys--basic understanding of the chemistry rocks!!
Vanessa
36,000 Vinyl SWG, Hayward t-15 running 80%
72 degrees
3200 salt
100 Alk
40 CYA
200 cal.
7.5 pH
5 Chl.
You never want to add two different chemicals at exactly the same time. But as long as you give it a minute or two between chemicals you should be alright.
If you use the sock method for adding CYA, don't pour the acid directly on the sock :)
