Thread: Where do I find Umbrella sockets????
    whoozer's Avatar
    Apr 2008
    Acton Maine
    I'm looking to purchase umbrella sockets to put in my concrete to accept umbrellas around my pool. I've seen a few pools with them but cannot find them anywhere. Any ideas?
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator ,
    Mar 2007
    Morris, IL
    Do you know anyone who can weld? How about a bit of pipe, with a reducer on one end, with some rebar welded onto the side about two inches down from the top? The reducer would keep the umbrella from poking all the way through, plus allow water to pass through. I would image that you could then get some sort of grommet to put in the top to cover it.
    I just looked around and found alot of them that go inside of a doorway to hold your rain umbrella's.... I will probably just make some. You could maybe even use a piece of PVC with a cap on it that would fit down in the hole to fill/cover it, put a hole in it so you could hook it to pull it out.
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Sep 2007
    Lafayette, Louisiana
    Check out S.R. Smith
    They make ladders, rails, diving boards, etc...
    They also have nice bronze umbrella sleeves with caps. ... rts150.pdf
    Fortune favors the well prepared
    The build...
    Freeform 24' x 38' IG gunite. 3 1/2' to 8' deep. 28,500 gallons. AutoPilot Total Control SWCG. Pentair Intelliflo VF. Pentair CCP520 cartridge filter. Colorlogic LED lights. Tahoe Blue Diamond Brite. 1200 sq ft stamped concrete deck.
    More details as they happen...
