Thread: Baraccuda G3 - well it does suck.
    So I'm not super have with my barracuda. It seems to be going in the same pattern again and again. Any thoughts?
    Gunite. 14,869 Gallons. Hayward cartridge filter. Hayward Super Pump 1HP. Chlorine.
    Baltimore, MD
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Baraccuda G3 - well it does suck.
    If it has an adjustable hose float or weight try moving it a bit, also make sure hose is not twisted and if that does not help you may try adjusting the way your return eyeballs are pointed.
    Ike
