Results 1 to 9 of 9
Thread: Aqualogic Losing Time?
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    The time setting on my aqualogic control panel keeps changing
    It's hard to get the pumps to run at the right time when the time keeps changing any ideas?
    Brian
    20K IG Gunite w/ raised 7ft spillover spa. 1.5 HP Hayward Northstar pump 425 sq ft Hayward cartridge filter, Colorlogic lights AquaRite SWG AquaLogic PS-8 control
    1hp pump for sheer descent
    22,542
    Re: Aqualogic Losing Time?
    I'd call Hayward and see what they say. I don't see a reference to one in the manual but a lot of units have a battery backup for the time and if that little battery gets low it throws the timeclock off.
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    Yeah, I think I will do that. I searched TFP and didn't see anything so I thought this was a weird thing. I will update my findings
    Brian
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    According to Hayward, my problem is indicative of a bad board - need to replace it.
    Brian
    38,248
    That is pretty disappointing that the clock can go bad and require a new board ... wonder if there is an easy fix like the current limiter (which Hayward also recommends a new board)
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by tagprod
    How much time are you losing? Mine loses a few minutes over the month but it really isn't a bit deal. I just don't think the units keep time very well and I am not sure it would improve with a new board.
    Mark
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    6 to 12 hours in a day or two.
    Brian
    mas985's Avatar
    Pleasanton, CA
    11,737
    Yea, that's not normal. I would check the solder joints on the board since that seems to be the biggest issue with the Goldline units.
    Mark
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    Got it swapped. Hardest part was paying for it
    Brian
