Thread: Heat pump cost per hour run time
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    How do I figure this out?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Heat pump cost per hour run time
    Electric cost: It is .102 per metered kWh.
    18'x43' Sport Pool
    DCAG's Avatar
    Jul 2009
    Merrimack, NH
    95
    16' X 24' Wilkes Pools "Genesis", 10K Gal
    Hayward Powerflo Matrix 1 hp, & 18" Pro Series sand (S180T)
    Look up the rated amps for your heat pump, which typically appears on a spec plate on the side of the heat pump. This will typically be a number like 40 or 50, though it might be anywhere from 30 to 80.
    $ = amps * volts * hours / 1000 * cost/kwh. For your case, if we assume the amps number you got was 40, that gives you:
    $ = 40 * 230 * 1 / 1000 * $0.102
    or about $0.93/hour.
    Real world costs will typically be lower, as the amp rating is usually peak usage, rather than average usage. This also assumes that the heat up is heating the entire time, and the pool never gets up to temperature.
