Hello, I'm was looking for non bias (or experience) on efficiencies of using a RayPak E3T (the 92 MBTU/h one) for a hot tub with about 650 gallons in terms of:
-- heating water temp = I saw in the forms that someone had said: 8 degrees an hour?
-- cost using electricity to heat water with this Raypak heater
-- how efficient is the raypak heater when elements are not optimal?
FYI: I don't have gas or propane
the old heat pump hasn't worked in long time. When it "did" work... it was nice that the water would get to 102
HOWEVER, years ago.. I didn't care or worry about cost, efficiencies, etc. I'm wiser now...or at least I'm older.
So looking at getting any heater and the lowest cost... yeah, I'm smarter now?
NOTE: I understand that even when the old heat pump worked, if the humidity was low and temp was cold (winter time)...
10 hours of running the heater would not heat the water more than a few degrees => frustrating, I remember those days.
WHY IN THE WORLD would some add a heat pump to the pool hot tube when it can't heat the water????
anyway, i'm thinking:
- technology has improved?
- there are better solutions?
I just need to ask people who know facts and/or solutions
which is why I posted this...
THANKS!!!
THANKS!!!
