Thread: Sunblock and Vinyl Liner
    Is that spray on mist sun block ok to use with a vinyl liner? Or should be stick with the lotion based stuff?
    Thanks, Justin
    2003 Marquis Euphoria - 400gal
    The spray on is fine. Any kind of suntan lotion may cause a slight oily slick in the skimmer. If that gets noticeable you might want to try a sucm bug or ball. They will soak up the oil.
    Excellent, thanks
