Thread: Circu Pool that keeps showing low salt
    yr old circu pool that keeps showing low salt after putting in two bags and also getting a water temp of 167f what can be wrong
    22,553
    Re: Circu Pool that keeps showing low salt
    Have you cleaned the cell?
    I think I remember a similar issue a while back. Use the Google search at the bottom left of the page to search and see if you can find it. Post back if you can't and I'll look a little when I have time.
    I had the same problem with an Intellichlor. There was some pretty mild calcium build up in the cell that came off with a muriatic acid wash and it worked much better after that. You should do that and check or have your salt checked.
    Walnut Creek, CA. 18k gallon Pebble Sheen + 1.5k gallon IG spa, 1.5hp whisperflo main pump, Pentair clean and clear 420, Intellichlor IC20, Polaris 360 w/booster,Jandy lite 2 natural gas, plus solar with Heliomatic 5000 controller and 3/4 hp booster
    Hi,
    The CircuPool techs are available six days a week; give us a call when you are at the unit and we will quickly determine the cause. One thing to check first is where the electrical cord plugs in the cell. Make sure the blue wire is on the middle terminal and that all three electrical cell connections are clean and tight. Lastly, if your pool water is below 50 degrees, the readings will not be accurate until things warm up.
    Don
    936-372-1515
    Don Uhle, Discount Salt Pool
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    422
    The water temp will greatly affect the readings. The units are set from the factory for 72% water
    At lower temps the salt will show too low. This is the same for Pentair.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
