Thread: water samples
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    water samples
    How long is a water sample good for? Say I take a sample in a drinking water bottle and cap it, and drive 20 minutes or so for the test. Is it accurate after a certain time, or does it lose something as it sits?
    20 minutes isn't that long. I wouldn't expect any problems. The chlorine level will go down over time but if you completly fill the bottle and keep it closed it shouldn't go down significantly in 20 minutes. It is also a good idea to keep it out of direct sunlight.
    Arizona
    924
    It should be okay. An opaque bottle would be better, I think. If you have a Leslie's (and perhaps other pool stores) they will give you a sample bottle to use. On the Leslie's bottle it states that it is best to have the water tested within an hour of collecting the sample.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    11,969
    Thanks! Will Follow your advice, I have an opaque bottle I will use instead.
