This is why you get algae in the spring. Closing with higher temps and opening with higher temps is your issue. It is allowing algae growth.
What type of cover do you have on the pool? If you can peel back a corner and test FC and use liquid chorine to chlorinate while covered would help. Drop a sump pump without any hose on it in an opened corner, turn it on, slowly pour in liquid chlorine and sump will distribute. Better yet, also throw in the dolphin if you have one. Maintaining FC once a week while it is "closed," likely will help you avoid algae.
