Results 1 to 8 of 8
Thread: Buzz in outdoor control panel
    Control panel buzzes when filter pump is not running. Ire placed a dimmer thinking that was it, but it still buzzes when pumps is not operating. Another control part?
    Re: Buzz in outdoor control panel
    It might be a transformer. What control panel do you have?
    Support the site
    Jandy Aqualinks RS
    Quote Originally Posted by JamesW
    Jandy AquaLinks RS
    May 2011
    Orange County, CA
    696
    Does this still happen when pool light(s) is off? Those low voltage lighting transformers are noisy. If not, I agree it is likely the main panel's step down transformer. Rubber washers placed under the feet of the transformer could help to reduce this buzzing.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    It buzzes with lights on or off. No buzzing while pump runs.
    Thank you.
    May 2011
    Orange County, CA
    696
    Okay, so it's not the lighting then. Are you sure that the buzzing goes away when the pump is on, or is it just that the pump noise masks the buzzing from the panel? In either case, there really isn't much other than transformers and the occasional bad electrolytic that can make that sort of buzzing. Is the sound disturbingly loud? A recent development?
    Somewhat annoying at night... It's near the master. Thinking its using electricity 24/7.
