Results 1 to 15 of 15
Thread: Gorilla Floor Padding
    Jun 2007
    MA
    165
    Any have one? I can't really find much about them online. Before I pay 64.99 for it I want a bit more info.
    Cheryl
    14X42 Intex Ultra Frame
    Casey's Avatar
    SW PA
    10,438
    I have happy bottom and I like it. It makes the floor so much smoother and hides foot prints.
    Mar 2007
    Morris, IL
    477
    I am happy with mine, I had my first pool without it and it would easily take foot prints in the sand below it, but now it is fairly smooth. The cove was nice too, even if I didn't use the happy bottom again, I would use the cove. But, I do suggest that you go with it.
    One of the guys I used to work with said he used it on his walls for insulation and he loved it. But, he never stopped spewing nonsense and stupidity so I don't know what to think, I never saw it myself.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Aug 2007
    Pensacola
    129
    Is this something that is installed under the pool liner? Can it be used in addition to the sand underneath the liner? Interesting product, wish I had known about it before my pool went up. How tough is the material against roots and such?
    24' AGP vinyl, 3/4hp Pentair 2-speed, Pentair Quad DE 60
    Pool Rover Jr.
    TF-100
    Mar 2007
    Morris, IL
    477
    I put sand underneath of the padding still, but I accounted for the thickness of the padding so I did not lose any depth. As far as roots go, I am not sure, but what do you have without it, just sand. I would guess that if a root wanted to get through it then it would. Roots can split rocks after all with enough time. Mainly though, as far as trees go, the roots don't spread much further than the "dripline" of the tree. So if you have a pool set up under trees, you would probably have some roots to worry about, if they are not directly under the trees, I would not worry about them. There are some pool installers and such here though that maybe have seen an impact by roots though. I would be more worried about the roots that are there say from a tree that was cut down where the pool was going to go. At that point, what I did, was I got a combination backhoe and just dug out all the roots, and that was my elevation for the pool bottom.
    steve
    Jun 2007
    MA
    165
    I guess I'm cinfused, can I lay this on the ground underneath my Intex pool? I was going to use a tarp then some said they used this under it.
    Cheryl
    No reason not to use it under an intex, that I can tell...
    sounds like it would definitely help with grass or weeds going up thru your pool...
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    DMAN11's Avatar
    May 2008
    Baton Rouge, LA area
    95
    Hmmm,
    I have heard of the happy bottom stuff, and recently while shopping was told about some kind of "thermal" padding also. It looked like bubble wrap with foil on on side, and is supposed to help warm you pool or keep it 3 degrees warmer, or something like that.
    This gorilla padding looks interesting, I may consider it.... And what about the wall foam, anybody recommend doing these things or do you guys think it's not worth the extra cost??? On the pool we ae getting, it comes with a pool cove, and a plastic covering for the ground to help keep out weeds and such, but this padding sound like it will give a softer bottom to the pool, what about it guys,,,,,,,,YAY or NAY????
    Thanks,,,,DMAN
    17,500g ; 16X32 Inground Vinyl
    Hayward 1hp ; SWG
    3/4hp booster on Polaris 280
    WHO DAT!
    GEAUX TIGERS!!
    Casey's Avatar
    SW PA
    10,438
    I give my wall foam two thumbs up! 8)
    Jan 2008
    Burbank, IL
    109
    I give the foam bottom a big yeay. It makes the bottom feel "really cool" according to the experts in my family.
    Wilbar 12 x 17 Buttress Free AG (~4400 Gal?)
    Hayward 225 sq ft cartridge filter
    1/2 HP Pentair Whisperflo
    Liquidator chlorine feeder
    Pool Rover Jr.
    BBB - it's the way to go
    I used vibrum
    I have horse stall mats on the bottom and 3 layers of insulation on the sides. this is impervious to roots or much of anything but rats and I haven't had those lately
    AG 4000 gal.13' round Louisburg(cedar sides,top rails) Vinyl liner commercial Watsu pool
    indoor, 96 degree, AutoPilot digital salt chlorinator, Chemtrol 250 automated controler
    CarefreeClearwater ion generator, Mecomatic acid feed, Whisperflo WFE-4 1 h.p. pump
    Pentair Master temp 250 HD gas heater, Pentair CC200 filter
    DMAN11's Avatar
    May 2008
    95
    quick question,,,,,,
    I am really thinking about this gorilla padding stuff, but can it be used at the same time as the plastic coating my PB is using??? They put down a thin hard plastic like coating to keep grass, weeds, etc... from coming through the liner. The way I am understanding is that this stuff would go on top of that lining, and then the liner will go on top of the gorilla padding,,,,, right??
    Anybody know of this first hand, is it nice to have or is Happy Bottom the only thing everybody uses??
    Thanks,,,,,DMAN
    Hayward 1hp ; SWG
    WHO DAT!
    GEAUX TIGERS!!
    mrsray's Avatar
    Sep 2008
    SW FL
    20
    Re:
    Quote Originally Posted by The Mermaid Queen
    I just got an intex pool with a gorilla pad .. . I got it to help with grass or weeds going up thru my pool
    the pad seems like it's made out of material ... does anyone know if it gets wet if it gets moldy etc?
    mine sticks out from the pool a little
    Intex Frame Setâ„¢ 24'x48" AGP, 9,951 gallons, 4000 gph Filter Pump, INTEX 56601 SWG, Skooba-Vac Vacuum, PoolDevil
    Re: Gorilla Floor Padding
    If you Carefully read what I wrote, you would see I said "No reason NOT to use it"!!
    8)
    mrsray's Avatar
    Sep 2008
    SW FL
    20
    8)
    I see that ... MY BAD ... thanks for pointing that out ... sorry
