Thread: Any type of system better?
    Hi,
    I'm going to be installing an above ground pool next summer, and was considering going with a salt water system.
    Are there any manufacturers to lean towards or stay away from?
    Thanks for your help,
    Eric
    16 by 32 foot IG, 14,500 gallon, vinyl pool, cartridge filter, SWG, heat pump
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Any type of system better?
    I'm happy with my Compupool system. That being said.
    Make sure you get a system 2 to 3 times your pool size. Why you ask? The daily output is based upon 24 hour operation (pump running). If your pump isn't running then it's not producing. Most people don't run their pumps 24 hours. Some 12 hours, some 8 or less. So you need to produce your daily usage (more chlorine) in the run time.
    Daily usage is based upon several factors, CYA level, bather load, and amount of sun.
    Here's the link in pool school: pool-school/salt_water_chlorine_generators
    It's good reading.
    Prices range for the units depending on features and size. A SWCG isn't necessarily cheaper, but it does reduce the work load.
    Check with the pool manufacturer if they'll honor warranty work with a salt water pool.
    Christian's Avatar
    Jul 2012
    Sacramento, California
    304
    If it's in the budget you can't beat the Pentair IntelliChlor system. That being said, the CompuPool system is also a great system and is less expensive.
    Christian's Avatar
    Jul 2012
    304
    Also I would recommend you check the warranty for your above ground pool. Most above ground pool warranties are voided by installing a salt system.
