We've got a copper scupper for a rain curtain that empties into the pool. I use the copper test kit from TFTestKits monthly and an never get a reading. Also, my daughter's blonde hair is still blonde, so if there's any copper leaching it's really quite minimal.
I am with Nutjob, (cant believe I admitted that).
We have been putting copper spillways on salt, and non salt pools for many years with no issues.
Your copper will patina quite a bit more.
Not sure where this tale began.
Probably from the use of copper piping. Copper is soft enough that if water flows through it at high enough rate it will scour copper away into the pool.
Your not generally running this type of feature with high flow rates that can cause this issue.
Here is a great company that makes the products, they will tell you how many thousands, and thousands of these they have in pools. http://www.bobewaterandfire.com/home
