Results 1 to 10 of 10
Thread: Slightly uneven?
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    Slightly uneven?
    We just noticed a bit ago that the pool isn't 100% level. Is this a problem that should be expected in an AGP? or is there a minimal allowable for being uneven, say a 1/4? Because that is about what it is.
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    1/4" is very reasonable.
    Mar 2007
    Morris, IL
    477
    Being out of level no more than 2" is fine, if you are only a quarter then I say that is awesome. My first pool was out of level a bit, the second time I tore it down and put it back up at my new house I used a rotating laser level and it was perfect. Having survived a few winters, and with frost heave and everything, I doubt it still is, but I haven't looked. AGP are meant to float I would imagine, which is why you should never allow your deck or anything solid to mount to the pool if it is set on footings.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Mar 2008
    Evans, GA
    323
    Thanks ya'll- weeellllll I just noticed a couple of other things. A few wrinkles in the bottom of the floor. ( CAN I GET THESE OUT?) and something else and I am not sure how this will affect the set up of the pool. Walking around the pool. I noticed that on one area that the pool wall seems a little "jacked up" like its not sitting flat (the track and the wall support beam) on the sand anymore
    Also one of the pavers that one of the support sticks was placed on seems like its not in place correctly. Actually I see several of these. Since they had to completely take down the pool and start over. I know I can't expect perfect. But do expect it to be done pretty darn close. I know once I turn the money over my chances of them coming back out for warrenty issues are nill. I bet they can't wait to get rid of me.
    *~ Laura ~*
    TF-100 Test Kit
    Butterfly's Avatar
    South Carolina
    10,045
    Suggest you take more pix of anything you question and post here for comments.
    Like you said, once they are paid, you'll probably have a hard time getting them back out especially this time of the year!
    You're done SLAMing when:
    Mar 2008
    Evans, GA
    323
    Here is what I am talking about. See how it is slightly lifted. The support beam is sitting on very little of the paver. The paver is actually shoved way up to far so that the back part of the beam is on nothing.
    See they covered most of them with dirt. So to check them you have to dig around all of them. :sigh:
    *~ Laura ~*
    TF-100 Test Kit
    Guest
    Quote Originally Posted by all your parts
    like they say close enough
    for government work.
    New Jersey
    51
    I don't think the posts on a round pool really do anything to support the pool once it is full of water.
    You have equal pressure pushing out which may then level a post that was originally a little low.
    I found a couple posts slightly raised after filling my AGP. I just pryed the blocks up and packed some soil under them until they were snug.
    I am sure one of the installers can give the definitive answer to this.
    Mar 2008
    Evans, GA
    323
    Well, we are almost squared away. The electrical is done the way I wanted and expected it to be done and is working fine so far. Now just replace the pool light and bring me the missing handrail for the steps and we are ready to swim!! That is as soon as I figure out the rest of those steps!
    *~ Laura ~*
    TF-100 Test Kit
