Thread: Can you ID the dealie?
    Jul 2012
    CA
    240
    I have 2 skimmers, one of them had this thing in hole...
    thanks
    [youtube:2iirfr78]QGEYgsVA-lQ[/youtube:2iirfr78]
    25k I/G ecostar ccplus Polaris plaster
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: Can you ID the dealie?
    That is a Vari-flo control insert. It is used to adjust skimming level and/or main drain suction.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Jul 2012
    CA
    240
    Edited to remove language filter circumvention. Please don't try to circumvent the filter. Bama
    hot ****! so i in theory, if i were to remove, there would be 50-50 skimmer-main drain?
    Im trying to find a suction side air leak, in either of lines.
    So do i just slightly rotate vari flow while in hole?
    THANKS!
