- May 31, 2013
- 89
Sand Cove OVER OR UNDER Foam Wall Insulation?
Is there any reason I can't build my sand cove (6" tall from everything I have read) and THEN hang the 1/8" foam wall insulation so that it hangs down slightly overlapping ON TOP OF the sand cove?
Here is why I'm leaning this way:
- We are right between rains again and trying to get everything done in bits and pieces now. We do as much as we can, then tarp everything to protect it, then uncover/dry/proceed. Slow, but definitely progress.
- Liner can't be installed until Monday at the earliest, and I don't want to hang the wall insulation very far ahead of that (would even like it to be on the same day liner starts so that I don't risk it falling down as we wait through the inevitable delays, weather, etc).
- Got the sand spread across the bottom with a large pile left for the cove...hoping this is a next step I could finish so it wouldn't have to be done after the wall insulation, which would make it the same day we do liner (because I anticipate it will take a LONG time to fill this enormous pond enough to smooth & adjust liner, so I really want to start with the liner as early in a day as we can). Therefore, if I COULD do the cove ahead and lap the wall foam on top of it later, this would be a time-saving jump start for my liner installation day.
- Figured that if an important factor of the cove is to keep liner from slipping down between it and wall, it would be an advantage to have the insulation draped over the place where sand meets wall??
However, if the foam wall nsulation may not be super easy to work with or drape smoothly, I don't want to go down the wrong path. Advice anyone?
Thanks in advance. I appreciate all the help here. Will post more pictures from the crew soon. Katie
