Thread: Wire it on the load side of the timer
    Chesapeake, VA
    5
    The RJ Series manual says to wire it on the load side of the timer so it turns on and off with the pump .... is this right or should the power be on to the RJ unit all the time?
    42x18 Grecian L, IG Vinyl, 33,000 gal
    Pentair FNSP60 DE Filter
    Pentair WhisperFlo 1hp WFE-4 Pump
    CircuPool RJ45 SWG
    Re: Wire it on the load side of the timer
    That is correct, the SWG should only be powered when the pump is running.
    Chesapeake, VA
    5
    Thanks Jason. I'll set it up accordingly next weekend....looking forward to seeing how the CircuPool works out compared to the Autopilot I had that died last month.
    CircuPool RJ45 SWG
