I've got an iChlor 15 plugged into a gfci outlet on its own 15 amp 120V circuit. My pool pump which is a single speed 240V pump is hooked up to a timer 104R which is powered by a 20 amp 2 pole gfci breaker. There are only 2 hots coming from the breaker, no neutral. I'll try to draw a diagram in a minute...
Is there any way to wire the iChlor 15 to the pool pump so that if the flow sensor fails it doesn't blow up? My understanding is that the ichlor 15 has a power pack instead of the power center which can only run off of 120V, not 240. The instructions say to cut the plug off and hook it up to the pump but it shows a 120V pump setup not 240, despite having 2 line 2 load connections?: (Page 34) https://www.pentair.com/content/dam...tment/ichlor/ichlor-manual-522709-english.pdf. Without a neutral on the GFCI pool pump breaker I can't connect one load side of the timer to the neutral to get a 120V connection right?
Only solution I can see is I would need to run another wire from the breaker load side neutral connection that's currently empty to the timer box to be able to hook one of the timer load lines and that neutral line to the ichlor power cable, right? Or is there a way I could wire something that senses when the pump shuts off and have it shut off the gfci outlet and turn it back on when the pump comes back on?
