Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 60
Thread: TFPC for Beginners old comments
  1. Back To Top    #21
    Re: BBB for Beginners
    Both.
  2. Back To Top    #22
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Shaf77
    Is BBB only for chlorine pools or also salt water?
    Salt water pools are also chlorine pools. The only difference is the method of adding the chlorine.
    You're done SLAMing when:
  3. Back To Top    #23
    Guest
    Thanks!!
  4. Back To Top    #24
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    I just bought a big tub of the chlorine bleach tablets/pucks at Sams for our new pool, which I will need to return now. Good info in this thread and throughout the forum.
    18,000 gallon in ground, plaster - completed 6/29/12
    Jandy 340 sq ft cartridge filter
    Jandy variable-speed 2 HP pump
    Jandy LXi 400 heater
    Jandy Aqualink PDA-PS4
  5. Back To Top    #25
    I am a first time pool owner and so glad I found your site! I am implementing your BBB recommendations and will let you know...I have been pool-stored to death!
    18 x 33 oval above ground; swimquip D.E. filter system
  6. Back To Top    #26
    Jun 2012
    Lafayette, Ca / USA
    260
    Ditto ... we just got our 1st taste of Leslie's Pools and got ripped $195 to replace a 16x36 solar cover (blue bubble wrap stuff). When we unfoiled the one that the previous owner had it started falling apart in the pool - so we were sort of in an emergency situation. Will do a better job of planning and price comparison the next time. But pool stores are now on notice with me.
    30,000 Gal FIBER GLASS (over Gunite Plaster) Pool, Dolphin Nautilus PLUS Robot, (2) Cartridge Filter System (old), 1/2 HP Pump, Full Sun, Solar Heated, TF-100 Test Kit.
  7. Back To Top    #27
    Re: BBB for Beginners - Ph and TA
    I am new pool owner, 25K gal, Pentair variable sp pump, SWG, Aqualogic, pentair clean&clear cartridge filter. Converted to BBB this spring, have had very successful summer testing and maintaining pool, water crystal clear all summer and still so. Salt= 2900, CYA= 80, FC= 4.5, TA= 80, borates= 50, all holding steady all summer. Ph creeping upward, now at 7.7, when reach 7.8 will add acid to lower to 7.5.
    Here's my question:
    TA is at 80, where I want it to be, now. When I add acid to lower Ph, will also lower TA. What do I do to bring TA back up to 80 without bringing Ph up.
    Thanks for your very helpful site.
    Really discounted & affordable seo services
  8. Back To Top    #28
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Baking soda raises TA and has little impact on pH.
    -sent with Tapatalk 2
  9. Back To Top    #29
    Guest
    New pool getting built in June with a SWG.
    So what do I need to do when its done? Start using BBB? Or?
  10. Back To Top    #30
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If it is vinyl or fiberglass start right away using the methods taught on this site. If it is plaster, check with your builder to see who is responsible and what type of start-up will be used.
  11. Back To Top    #31
    Guest
    Quote Originally Posted by linen
    It will be a vinyl pool.. Still figuring out design and where to have it on a 50'x240' lot.. Closer to the house or at the back?
  12. Back To Top    #32
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I responded in your build thread.
  13. Back To Top    #33
    Apr 2013
    North OKC Area
    298
    I would like to request that "The Pool Calculator" have a small change for those of us that use the webpage on our mobile phones. If you change all <input type="text"> to <input type="number">, the default keyboard page on our phones will show us the numbers first instead of letters.
    The change is supposed to be backwards compatible with browsers that do not support HTML5 and it will default back to text. On Opera, Safari, and Chrome it adds up/down arrows to the right of the field which may change cell widths, however I'm sure jQuery could be used to detect the browser and only change the input type if it is a mobile device.
    17,100 Gal 27' x 52" AGP steel wall vinyl; 44gpm Cooper sand filter; Hayward 1hp sp1580 single-speed; 1.5" plumbing, 1 skimmer/jet, inline chlorinator.
    Chlorine / CYA Chart | SLAM Process | Chlorine cost/fl. oz calculator
  14. Back To Top    #34
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Unfortunately, JasonLion the creator of the pool calculator, no longer controls the rights/ability to change the webpage. Have you tried one of the apps? 2 for android: simple pool, pool pal (I think) and one for ios: pool-calculator
  15. Back To Top    #35
    Sodium Bicarbonate(Baking Soda, etc). I get mine at a local Co-op type place. Actually an animal feed store. $17 for 50 lb!! Can't beat that.
    21K IG Vinyl; Hayward Sand Filter
  16. Back To Top    #36
    Darko5500's Avatar
    Aug 2013
    Sydney AUS
    17
    Why shouldn't you use Dry Acid (Sodium Bisulfate) with SWG to lower pH?
    Pebble 63kL - Waterco S602 (Zeolite) - Hurlcon EVO P300 3 sp 1KW.
    Watermaid SWG QT150 cell - Polaris 280 Cleaner.
    Spa - spill over (no heater at the moment).
  17. Back To Top    #37
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by Darko5500
    Where did you see that in print?
  18. Back To Top    #38
    Darko5500's Avatar
    Aug 2013
    Sydney AUS
    17
    "Dry acid is easier to work with than muriatic acid but costs more and should not be used with a SWG."
    This was under the pH heading on the initial post.
  19. Back To Top    #39
    Mar 2007
    San Rafael, CA USA
    12,082
    If you use a lot of dry acid, then sulfates can build up in the pool and at high levels (300 ppm) they can be harmful to plaster (see this thread). Some saltwater chlorine generator manufacturers say to avoid using dry acid, though their claim of calcium sulfate formation is questionable. Calcium sulfate scale would take quite extraordinary levels of both and it is not pH dependent the way that calcium carbonate and calcium phosphate scale are. It's possible that there is some other factor of sulfates on the special coatings on SWG plates, but that is just speculation.
  20. Back To Top    #40
    Nov 2013
    San Diego, CA
    5
    About how much gallons of chlorine should I expect to use in a 20,000 gallon well maintained pool??
    Just trying to think about the expense monthly.
    1.) POOL: ~20,000 in-ground (plaster)
    2.) FILTER: Hayward MicroClear Vertical Grid D.E. filter (DE 4800, 48 ft. sq. , 96 GPM)
    3.) PUMP: Hayward Super Pump 1.5 hp
    ...pool was re-plastered ~1.5 yrs. ago
    ...small spa with jets but no heater
