Thread: pentair easy touch 8 single body
    I just bought the easy touch 8 single body,
    I can't find any where in the manual where it tells
    What kind of breakers to use in it..i don't know if it takes
    Sqaure D ,siemens or what?
    22,551
    Re: pentair easy touch 8 single body
    It uses standard plug-in breakers. The ones you get at the home improvement stores should work fine.
    May 2011
    Orange County, CA
    696
    Actually, the inside of the cover will describe the different kind of breakers that are compatible. I know the Murray GFCI 1P and 2P breakers are compatible. You definitely want to use GFCI protected breakers whenever possible for this type of application.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
