Results 1 to 15 of 15
Thread: Cracked skimmer
    Cracked skimmer
    How can I repair that vertical crack?
    Thanks, Joe
    New Jersey
    - 15ft round Above Ground pool with vinyl liner (10 yrs old)
    - 5700 gallons, Sand Filter, 1.5hp pump
    Casey's Avatar
    SW PA
    10,438
    Re: Cracked skimmer
    Replace the skimmer box. It's not hard, just drain below the box n put the new one on.
    Re: Cracked skimmer
    Quote Originally Posted by Casey
    I know I can do that. No funds to do that now. I was looking for some kind of putty or something like that.
    Thanks, Joe
    New Jersey
    Re: Cracked skimmer
    I just finished hard plumbing and I think I put too much Teflon tape on the PVC adapter and tightened it too much. I did the plumbing Monday morning and just noticed the crack this morning. I'd like to get by the rest of the summer with just a repair and next spring I can replace the entire unit. Is it at risk for further cracking and posible failure?
    Thanks, Joe
    New Jersey
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: Cracked skimmer
    Yup, torqued it a bit too tight.
    If it's just a temp fix you can cruise your local hardware store for water proofing putty that goes on the outside. I've seen it at home depot but I don't know how well it works.
    Note, if you ask they'll probably tell you there's no such thing, I went to 3 stores locally and no one heard of it even though I knew it existed, then just a few weeks ago going thru the plumbing section of home depot - there it was, saw it by accident.
    It may buy you some time.
    Re: Cracked skimmer
    This caulk is what I used when I built a fish tank, perhaps it can be a solution for your problem.
    6,500 Gallon 18'x48" Intex Ultra Frame
    Intex 2,650gph Pump & Sand Filter
    Intex SWG
    May 2012
    Corinth, Texas
    14
    Re: Cracked skimmer
    Marine Tex epoxy putty.....they use it to make temp repairs to boat hulls.....can be used underwater also....it may work for you...I think Permatex makes a similar product they sell at Walmart.
    IG Gunite pool built in 1994 3ft/5ft/3ft about 10-12000 gallons, Pentair Challenger 1-1/2 hp pump, Pentair TR 60 Sand filter.
    Jun 2012
    MA
    347
    Re: Cracked skimmer
    Even if you fix the crack it will probably leak at the threads. You could fix it with epoxy but I would also epoxy the threads on the fitting.
    Re: Cracked skimmer
    Quote Originally Posted by 1380ken
    I should remove the Teflon on the threads first before putting epoxy on threads, right?
    Thanks, Joe
    New Jersey
    poolgranny's Avatar
    May 2012
    Mid-Missouri
    120
    Re: Cracked skimmer
    If you put it on the threads will you then be able to screw that piece back on? It looks like it would mess the threads up.
    Could you put on the crack and on the joint where the pipes fit together? I am by no means a plumber just curious.
    Above Ground Pool 15' by 30' Older pool -- Make ? Model ? Cost - Free; Given to Us
    Gallons approximately 11,000 (if I figured correctly)
    New liner in 2007 when pool was moved and installed by son-in-law and family members
    Hayward Sand Filter 150 pounds of sand (purchased new in 2007)
    White River 2 horsepower pump (purchased new in 2012)
    Deck built in 2011
    Bioguard 1200V Multi-Test Kit with an additional Orthotolidine Chlorine Test Kit
    asxetos's Avatar
    Jul 2012
    Athens, Greece
    99
    Re: Cracked skimmer
    If I had to repair that, I would use only mechanical means, as this kind of damage needs mechanical support anyway.
    A couple hose clamps and a piece of suitable diameter hose pipe slipped over the damaged part would do the job in a semi - permanent way.
    The clamps and hose pipe piece should be slipped over there without disturbing the damaged joint itself.
    Just my 2c.
    Donīt be fooled by the sheep on my bike, I swim with fish in my sound equipped pool.
    Re: Cracked skimmer
    Quote Originally Posted by asxetos
    Just my 2c.
    Great idea...I already used something called Water Weld from Homedepot.I will do that as insurance, thanks.
    Thanks, Joe
    New Jersey
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Cracked skimmer
    If you are going to spent that much on glues, tubing, and hose claps... whey not spend $37.95 and get this?
    http://www.bestbuypoolsupply.com/product3332.html
    No interest, I just know they have them for cheap.
    -- Guy --
    poolgranny's Avatar
    May 2012
    Mid-Missouri
    120
    Re: Cracked skimmer
    I spent $24.00 for our skimmer. I purchased it on eBay and that included the shipping. It is regular size and worked perfectly. It had the fittings and gaskets, etc.
    Doesn't have a brand name on it, but seems durable and fit the hole exactly that was already in our pool. Our original skimmer that came with our pool (free) didn't have the skimmer door weir. The basket had cracked and wasn't catching most of the leaves etc. so decided to switch it out.
    Deck built in 2011
    Re: Cracked skimmer
    I had a big crack on my skimmer and I used clear indoor outdoor caulk..I put a big glob on and smoothed it out..let it sit a couple hours and repeated..I did this a few times..not a single leak.
    13500 gallons
    Intex 2650 Sand filter pump
    AG
