Results 1 to 9 of 9
Thread: Return eyeballs
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Return eyeballs
    What is the proper direction for the eyeballs? Should they point downward, towards the surface, towards the skimmer?
    How do you have yours pointed?
    Thanks
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    Guest
    i have 2 up and 2 down.
    hodapmj's Avatar
    Oct 2007
    Arkansas
    54
    Re: Return eyeballs
    Quote Originally Posted by meatloaf
    Thanks
    I keep my three pointed just downward so that I don't break up the surface water and then pointed towards the nearest skimmer basket. This keeps a nice circular flow around the pool, drives debris to the skimmer baskets.
    24K gal. 22 X 40' Fox Lagoon IG Vinyl, 7' Fox 25 jet raised Spa, Intelliflow VS-3050 pump, Intellichlor IC-40 SWG, Pentair Easy Touch Controller, Easy Touch Wireless Remote, Pentair Legend cleaner w/ booster pump, Pentair 250,000 BTU heater, Pentair Tagelus Sand Filter, & Pentair Intellibrite LED lighting.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Return eyeballs
    Quote Originally Posted by hodapmj
    Thanks
    This is what we do, too. I have heard that some test the flow w/a ping pong ball.
    You're done SLAMing when:
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    It depends on what you need. I live in the country, so I have a pretty big bug load. I want maximum flow to my skimmer, so all of my returns are pointed toward the surface.
    Jan 2008
    Burbank, IL
    109
    I point mine down a little and to the side so that it makes the pool swirl like a toilet bowl. Everything seems to get into the skimmer that way. Then I throw my scum ball at various places in the pool to see if it gets back to the skimmer.
    Wilbar 12 x 17 Buttress Free AG (~4400 Gal?)
    Hayward 225 sq ft cartridge filter
    1/2 HP Pentair Whisperflo
    Liquidator chlorine feeder
    Pool Rover Jr.
    BBB - it's the way to go
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    OK Thanks, I also have mine pointed just below the surface and angled to create the toilet bowl effect also.
    Just wanted to make sure I was doing it right.
    Guest
    since i have two skimmers, i find i get better chemical circulation if one shallow end return is up, and one is down, then awsome skimmer action if one deep end return is up and the other is down, but every ones situation is different.
    mas985's Avatar
    Pleasanton, CA
    11,742
    What ever works.
    No I'm serious. I fiddled with mine for some time and found the best circulation, skimming and heat distribution. But I bet that every pool is somewhat unique. Trial and error is best method.
    Mark
