Thread: Grounding our pool
    Grounding our pool
    We have just installed a 24 ft round above ground pool sharkline matrix. The pool is already filled with water but we now need to ground the pool. Is it safe to undo a side post with water in the pool?
    Burlington Twp, NJ
    ProSeries 20x48 AG
    8000 gallons
    Proline Sand Filter 55gpm
    22,551
    Re: Grounding our pool
    I assume you mean bonding instead of grounding. Matters not. It should be fine to remove an upright, but you could actually use a self drilling screw to attach a bonding lug to the bottom of the uprights without removing anything. Post a pic of the uprights and we can make sure it's safe to do.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Matrix uprights are resin so you don't want to tap the bonding lug into those.
    You can pull off the upright cap at the wall seam and you should be able to get a bonding lug onto one of the upper wall seam bolts (undo nut, apply lug, re-apply nut). Personally, I'd be worried that you wouldn't be able to get the upright seated properly again if you took the whole thing off.
    Quote Originally Posted by cramar
    There was another Matrix user that did exactly what you described, couldn't find it again. I agree with cramar though, try to get at the top bolts under the cap.
    24 Ft Sharkline Matrix , ~15,200 Gallons
    Pentair SD60 w/ 2 speed 1.5 HP Dynamo pump
    Taylor K-2006 --- BBB
    22,551
    Sorry I forgot that the Matrix uprights were resin.
    My pool is bonded to the wall seam bolt. It's pretty easy to do once you get the cap off and see how everything is put together. We weren't required to bond it in four places since it's a solid metal piece.
