Results 1 to 12 of 12
Thread: chlorine/bleach bottle recycle
    Oct 2010
    michigan
    284
    Do you guys recycle your chlorine/bleach bottles?
    i can recycle bleach bottles but over here its cheaper to buy the chlorine bottles from pool store or hardware store.
    my recycle place says no chlorine bottles
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: chlorine/bleach bottle recycle
    I buy the refillable ones from my local pool store.
    Guest
    We have curbside recycling and they have always taken mine.
    Oct 2010
    michigan
    284
    Quote Originally Posted by DeeMac
    bleach bottles or the chlorine bottles? obvious you leave the caps off?
    Sep 2011
    Omaha, NE
    95
    [/quote] bleach bottles or the chlorine bottles? [/quote]
    They are the same thing....... Why would they take one and not the other? I am confused
    16X24 Oval Doughboy
    10,000 Gallons~
    Pentair Dynamo .75/1.0 HP pump
    16" Pooline D-400 Sand Filter w/ 6-way valve
    38,275
    Quote Originally Posted by fritz614
    Because bleach and pool chlorine are COMPLETELY different ... as anyone who takes the RTD/PSC* training knows.
    *Recycling Truck Driver / Pool Store Clerk
    Aug 2010
    SW of Kansas City
    100
    Why?...because some people leave up a couple ounces of liquid in a bottle without rinsing... This is a hazard for the guy that has to sort it.
    I've never had a problem recycling bleach, or any other household chemical bottles.
    I always rinse thoroughly...and bleach rinses very clean.
    How clean? Most of my empties get their tops cut off after rinsing and are used as containers for plants and even live fish!
    The only problem I have is they now will not take empty oil bottles...and I do oil changes on 3 cars myself...
    16'x32' ~20000 gallon Vinyl in-ground pool. Single skimmer + bottom drain, dual return. Hayward 244T Sand filter and 1.5HP 2 speed Super pump running 24/7
    24' round ~13500 gallon Vinyl above ground pool 1HP single speed Pentair pump 24/7 with Sand filter. Next door---Maintaining it for my great neighbor!
    Aug 2011
    Texas
    45
    I just toss them with the rest of the recycle. Of course I always rinse the bottle with a little pool water to get every last drop out
    12k gal gunite, Sunstone Plaster, Pentair IntelliFloŽ VS+SVRS Variable Speed Pump, Pentair Intellichlor IC-40, Pentair CCP520 cart filter
    Guest
    I also dip mine in the pool to rinse it out and get the last drops.......lol
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by kj5kb
    Use the oil bottles to take the used oil back for recycling.
    Aug 2010
    SW of Kansas City
    100
    Quote Originally Posted by JohnT
    Good idea...in theory
    Not to derail the thread...but...it's WAY easier to drain all the used oil into a 5 gallon container for bulk recycling. And the local places that recycle used oil make you take back your containers anyway..
    ON Topic...kinda...
    The household bleach I buy has plastic sleeves for labels...I cut those off and reuse the rinsed bottles as containers or recycle 'em
    Havent seen liquid pool chlorine around here, (Cleveland OH) but trash co (Republic) hasn't said it's a problem.
    Jun 2007
    New Jersey
    653
    ON Topic...kinda...
    Underlined is not universally true. This depends on your local recycling center. My town ONLY accepts oil in containers that they keep. My county accepts oil either way and they will keep original containers. I have to ask to get my big one back when I use it or they'll keep that. Since the town is open M-F and the county only once a month on the first Saturday, I do all my oil in the original containers. I still have to go to the county for coolant, as the town doesn't do that.
    My county says not to recycle bleach, but I rinse well and cut off the label sleeve and they always take them.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
