Thread: pump on/off when adding bleach
    iam4iam's Avatar
    May 2012
    Johnson City, TN
    228
    This may not be deep enough for the deep end, but will the bleach distribute sufficiently enough by diffusion or should the pump be running when adding bleach?
    ~18,000 gal (16x32) vinyl
    Hayward sand filter
    Circupool RJ45 SWG
    Hayward Max-Flo XL SP2305X7 pump (0.75 HP)
    22,553
    Re: pump on/off when adding bleach
    Pump running. Delve into how the Liquidator operates and you'll learn why.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Definitely pump on. With any chemical (In my case mostly bleach and MA) I also go through the extra step of diluting in a 5 gallon bucket of water before adding to the pool to avoid a concentrated slug in any one spot. If I need to add both, I do them in separate bucket loads.
    Mar 2007
    San Rafael, CA USA
    12,082
    If you've got multiple returns in the pool, then adding the chemical slowly over a return flow in the deep end works really well since it has a lot of volume of water in which to dilute quickly, it has floor drains and/or skimmer to get back to the pump, and it then gets distributed to other areas of the pool via returns. If the chemical is relatively innocuous such as baking soda, then adding it to the skimmer to have it come out the returns also works well, but you definitely don't want to do that with acid (with chlorinating liquid or bleach I personally avoid that except on occasion, but we haven't seen reports of it being a problem).
