Thread: BACKWASH??????
    BACKWASH??????
    after backwashing my sand filter when i start the pump back up after backwashing it pumps sand or fine dirt back into the pool .
    i changed the plunger already.
    need help
    26,000 gallon in ground
    in floor caretaker system
    sand filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: BACKWASH??????
    Are you running it on the rinse position before going to filter?
    Ft Lauderdale, Florida
    1,455
    Re: BACKWASH??????
    Is this a new filter, or did you just replace the sand?
    It may be just sediment blowing through and will subside soon.
    If it's older sand, you may have a crack in one of your filter laterals.
    There's also the Rinse position on the valve, which "settles" the sand back down before going back to the Filter mode.
    Filter --> Backwash --> Rinse --> Filter
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Re: BACKWASH??????
    I am not sure what you are asking.
    sand filter
    Re: BACKWASH??????
    my filter is less than a year old ut no real new. the planger pushes down to backwash and pulls up to lock in place to filter. i don't know what you mean by rinse.
    sand filter
    22,553
    Re: BACKWASH??????
    You have a slide valve. There's no rinse setting.
    You most likely have a cracked lateral.
