Results 1 to 9 of 9
Thread: Minimax HP 400 ; T-Stat wont run!
    Hey Mates
    First of all, sorry for my bad English, I came from Germany.
    I've got a big problem with my Minimax HP 400.
    All control Lamps :Control, Pool, Water Press. Ok are blinking.
    But the T-Stat Lamp wont blink. Did the Thermostat crashed?
    The Unit didnt run at once ..
    What can i do to fix my Heater?
    Thanks
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Minimax HP 400 ; T-Stat wont run!
    Mine did that once. I just killed all the circuit breakers on the pool panel for about ten minutes then turned them all back on and it reset itself. Hopefully you'll get as lucky..
    Thanks
    Can you describe the " I just killed all the circuit breakers on the pool panel for about ten minutes then turned them all back on and it reset itself." part more nearlier?
    My fault at the beginning was, I thought that the plug from the TB2 was the power supply (there was written PO, I thought this means POWER) and connected the power supply on this. So i destroyed the Potentiometer. I hope that I doenst destroyed the circuit board too. But the board doesnt give a smell!!
    I just connected the both black cables from the Potentiometer together, so the Thermostat is running on full power, am i right?
    Please correct me when iam wrong with one of these statesment, it very important for me!
    Richard320's Avatar
    Jan 2010
    18,967
    My panel has circuit breakers instead of fuses. So I just turned them all off.
    I haven't gone nay deeper than that troubleshooting my heater, so I'm no more help to you.
    Yes, my Heater got this curcuit breakers too.
    So you turned all of them 10 minutes off and then the t-stat worked again fine?
    How did u turned them off?
    Thanks.
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by onehitopfa
    Thanks.
    They look like light switches mounted sideways. I just pushed them the other direction. There's no way to say it without being insulting, but if you don't know how to turn off a circuit breaker, you probably shouldn't be messing with electrical stuff.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Thanks
    This means to remove power for a while, then re-apply power. In this case, the power was turned off by switching the mains switch off, then back on.
    I do not know enough to assist with this part. Have you contacted the manufacturer?
    Hey.
    Yesterday, an electrican was here. He just testet all the components and he said, the Potentiometer is crashed hard!
    The whole plantine is black and smell very hard.
    My question is now, how mutch ohm (?) and Watt {n} the Potentiometer got?
    I would buy a new one in Germany, cause the original Potentiometer cost about 55$ incl. Shipping to Germany.
    In Germany normally the poti's cost about 3-5$.
    I hope u can help me.
    Hey!
    Today is recieved my new Circuit Board and Potentiometer!
    All Control Lamps are running, and when I start the Machine, all the LED's are blinking and the Fan is running, but nothing else!
    The machine doesnt give any other noises!
    I read that afer 90 Seconds the compressor should be running, but this didn't happend to me!
    And after about 5min, the whole Machine is shutting down and my circuit breaker trips is shutting down too!
    Iam running the Minimax in the spa mode, but in the pool mode, exaclty same things are happen!
    Can you tell me what the Problem is right now?
