Results 1 to 11 of 11
Thread: water truck or hose
    May 2011
    South Texas
    23
    water truck or hose
    We are installing this weekend!!! I'm concerned about burning out our waterwell pump but having trouble finding a water hauling truck for hire or rent! How have you all filled your pool at original install???
    Assisted install/DIY project 2012: 15,000 gallon ,15x34x6 Fiji by Viking fiberglass pools with Azure blue diamond finish, 1 1/2 hp dual speed pump, 30" Hayward Sand filter, inline tablet Chlorinator (at least until I decide on a SWG- this is ALL new to me)
    water truck or hose
    Check with your local fire department, sometimes they will fill pool's but some have stopped doing this unfortunately.
    Worth a call anyway
    We had to fill our pool with the hose, took like 3 days but it will fill
    18' x 33' Aqua leader AGP (~19k gal) w/hayward swimpro voyager cartridge filter and 2hp hayward pump.
    8 Gal LQ, hayward heater.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: water truck or hose
    What I have found is if you are on a well you need water hauled in. If you are on city water it's much cheaper to use a hose.
    Are any of your neighbors close enough by that you can use their hose along with yours to take the strain off your pump?
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    May 2011
    South Texas
    23
    No close neighbors, so that won't work. Someone suggested putting a timer on our water well to run about 20 min then shut off for 5 min to prevent over heating. Anyone think that would be helpful????
    I still can't find a truck but about to call the fire dept, unfortunately we only have a small all volunteer force here in rural South Texas.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    My pool took a couple days by hose, personally I wouldn't recommend with a well....but if there's no other options.
    Try your fire department, if not then try contacting a local company that does road (re)construction or paving, locally the companies here have a bulk water agreement with our utilities commission that allows them to fill tankers from fire hydrants, these same companies will do pool fills. I think it's a bit of a loop hole in the agreement, but whatever.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,084
    If you have a bill that combines water and sewage make sure to call the water department first. Most will give you a brake on the sewage as you're not cycling the water....just using and "storing" it.
    Dec 2011
    Murfreesboro, TN
    111
    We began filling our pool from a garden hose on Wednesday evening with city water. The fill process went something like this for our 7' deep ~23K gallon pool.
    Wednesday - 7hrs - bottom 3' filled - stopped upon PB request - need to cut-in vinyl around light fixture - turned off water at midnight
    Thursday ~ 15hrs - fill rate appears much slower (larger area being filled), level is now 3ft higher - stopped at midnight
    Friday morning - turned on water at 6am - final foot of depth should be filled in ~4hrs. (guess)
    Total time will be somewhere around 26hrs
    I contacted our local water/sewer utility this morning on advice from some coworkers. The utility will send us rebate forms in the mail. Since pool water will not be returned to the sewer system for treatment they offer a refund for that portion of the bill. In my case sewer is about 40% of the monthly bill. So instead of paying ~$350 in water and sewage fees when all is said and done it will have cost something like $200 to fill the pool. I'm guessing it would've taken at least 2 trucks to fill my pool and the water plus delivery fees would've been much higher than $200.
    Hope you find this info helpful.
    22 x 36 In Ground Vinyl - 23K Gal - Saltwater - Tara Liner
    1hp 2-speed Hayward Super Pump, Hayward 6060 Booster Pump
    Hayward SwimClear C3030 Filter, Hayward 400Btu NG Heater
    Hayward Aqualogic PS-4, Polaris 280 Cleaner, ColorLogic 4.0 LED
    When we had our pool installed the pool store suggested a guy to truck in water. I noticed he got his water from a hydrant across the street. Possibly ask the pool store if they can suggest someone to haul in water. We paid around $125, I believe it was about 4k gallons (then filled the remainder by hose). I remember it being quick, maybe half an hour.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Feb 2011
    Petaluma, Ca
    665
    Filled from our well, took 21 hrs to pump 33000 gal +-. I had 3 hoses running full, did'nt think about the pump possibly overheating although since it is submerged withh approx 100' of water above it I doubt that could happen. If the water level dropped to the pump maybee it would have. My well documentation claims 50 gal per minute, but 21 hrs for 33000 gal equates to approx 26 gal per min. We have good water here with no iron, but a little manganeeze, and it's a 9.5 on the hardness scale.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Mar 2010
    Quakertown, PA
    50
    Many volunteer fire departments sell tanker loads of water as a fundraiser. The department I belong to doesn't; it doesn't have a tanker, filling with an engine would take too many trips, not cost effective. So, don't be afraid to inquire.
    Arvil, 30ft round, 21k gal, AG/vinyl(2003), StaRiteIII hp cartridge 150ft, Polaris65.
    6/30, Temp83F (28.3C), pH 7.8, FC 2.8 ppm, CC 0 ppm, TA 100, CH 80, CYA 40, -B4O7 30, CSI-0.17.
    Try to find a paving co they all need water for rollers.The trucks should have a pump on it.
