- Aug 26, 2016
- 50
- Plaster
- Pentair Intellichlor IC-60
I have been mostly lurking on this site and it has been an amazing boon to someone who knew nothing about pools/maintenance just a few years ago. Thank you to everyone for the great information and discussions.
So I have been able to bumble along fairly effectively and maintain my pool for the past few years. So far I have been able to do everything myself (with the help of these forums). But the pool is old (20-30 years?), has definitely seen some wear, and I probably need to make improvements at this point. Not sure quite where to start.
It had a single speed 1.5 HP pump which I replaced the first year (put in a variable speed intelliflo).
Here are the other issues I am looking at:
Thanks in advance for all advice!!
-Steve
- The previous owners left their suction crawler (I think it is a hayward phoenix?). Not sure how old it is but it is constantly stopping, needing attention, and more than once has contributed to problems maintaining the pool chemistry because it was not cleaning. I have dissected it, lubed it, and reassembled multiple times. But the treads are gummy and disintegrating and the internal fins keep getting stuck even without any debris (they catch on the side). It seems like Dolphins are popular cleaners here. I assume this better than the suction side cleaners, but I don’t know. What are the pro/cons of dolphin vs. maytronics, models, online vs. local vs. phone orders etc.?
- The system has (had) an auxillary pump which also crapped out the first year after we moved in. It seems to only add power to the integrated spa and runs a blower. I haven’t replaced it yet because we can still use the spa but some of the jets don’t work and we don’t have the bubbling spa effect. But it is on my list of fixes - Any suggestions on replacement pumps etc.
- Old plaster - most noticeable in the spa where it has 2-3 inch areas that have come off. But the whole pool is highly pitted. Is this something I can patch/fix or is this best addressed through a whole pool replastering? When do you know this is something that has to be addressed and can’t be just ignored or put up with? Obviously, it is not pretty and I don’t chose to ignore it but I’m assuming this would be pretty costly. I would love to redo it as the plaster is a terrible off-white yellow/green color and even when it is in top condition it just doesn’t have that sparkling clean look.
- Related to number 3 above - I’m pretty sure I have a black algae issue which is exacerbated by the deep pitting. It is kept at bay with proper maintenance of chlorine but it is everywhere when I look closely in the pits. I just don’t seem to be able to brush it effectively and multiple slams have failed to remove them. Any thoughts on how to address?
- The pool lights are very old and show gaps from the pool. I’m sure there is probably a source of algae coming from them. There are only two 1-foot lights, one in the pool and one in the spa. We asked the previous home owners to fix the spa light but apparently the ground/concrete decking have settled and crushed the conduit so a new light couldn’t be installed. Instead the lines were cut to remove any electrical risks. Are there other alternatives for lighting? The pool light still works, should it be replaced? Or is there a way to clean behind it and reseal? (It’s located about 3 feet down so I’m guessing the pool will have to be drained?)
- Do drains need to be cleaned / augured periodically? I have two, one in the deep end and one in the spa. I keep imagining years and years of Crud is built up which might be contributing to circulation issues.
- The pool had two skimmers, on opposite sides of the length of the pool. When the inspection was done, they found that the deep end skimmer had been closed. The previous owners had only lived there 2 years and knew nothing about the pool history. I have no idea why it was closed off or if there is any problems with the plumbing. The inspector speculated that it may have been done to increase the suction of the other skimmer for the purpose of running the crawler. My question, do I dare re-open the other skimmer after 6-15 years probably?
- I know this is way too many questions for one post but it is has been helpful just to get all my questions written out so I can see all the issues. So obviously, I’m not going to be able to address all these issues at once. Therefore, my last question is, which should be my priority(ies)?
-Steve
