Results 1 to 7 of 7
Thread: SWG chlorine output rating
    Fairfax Station, VA
    52
    SWG chlorine output ratings are published as pounds per day. I think it would be useful to know the approximate total lifetime output to compare units. Is this data available anywhere?
    35K gallon plaster IGP, free form, spa with spill-over; Sta-Rite 2HP pump; KDI American 48sq.ft., 144GPM DE filter; Pentair MiniMax heater; pressure side The PoolCleaner; Circupool RJ45
    South Central NJ
    3,192
    Re: SWG chlorine output rating
    Most brand name cells are rated for 10,000 hours of use immersed. Winterized units time doesn't count.
    Non brand name or generics are usually rated for less time and have much shorter warrenties.
    Scott
    Owner of - PoolGuyNJ LLC
    iggy's Avatar
    Jan 2008
    The Cool Part of Arizona
    175
    Just for one example.
    My Goldline SWG has been running for 3 years now.
    Being in Arizona we run the pumps and SWG probably 6-8 hrs a day from June 1 to Sept 30
    The rest of the year 2 to 4 hrs average a day
    I figured I have run the cell close to 4,500 hours and it is still going strong.
    I usually run it from 60 - 70 % during summer and 35 - 40 % the rest of the year.
    One thing that helps is my water hardness (calcium) is low and runs 220 to 250 which is low compared to many.
    This means I get very little calcium buildup on the cell interior.
    So to help answer your question cell life relates to many factors which are different for each user.
    At least this will give you some idea of mine.
    In-Ground SWG pool 11,000 gal., Jandy CL460 Filter, 1.5hp Stealth Jandy pump, Paramount PV3 In-Floor cleaning sys., Goldline SWG, Hayward Color Logic 2.5 LED Light
    mas985's Avatar
    Pleasanton, CA
    11,741
    I'm on 6.5 years of run time on my Goldline SWCG. No winterization and an average daily run time of 8 hours in the summer and 2 hours in the winter at a setting of 40%. That is about 57000 hours of immersed time (no winterizing) and 4800 hours of actual on time. I think the lifetime of the SWCG is based mostly on the amp-hours usage of the unit and time in water is much less important although at some point it probably becomes important.
    Mark
    South Central NJ
    3,192
    On time is what I should have said. Immersion time is important though as there can be some water based friction on the blades inside from the water going through, even when the cell isn't generating.
    Scott
    susa's Avatar
    Oct 2010
    Deep South
    578
    only going on my 2nd year but based on diagnostics from IntelliWand and from disassembly and looking at the cell plates (they look identical to brand new cell), my guess is that I will get somewhere between 3-5 years from this unit.
    it does help to have the Simpool inject small quantity of diluted acid into the line, just prior to the IC40 cell while the system runs a cleaning schedule, current schedule is 14 hours/day and 3 days/week with IntelliFlow running 24 hours/day at 95 watts (IntelliChlor is automatically turned off at power use below 125 watts).
    iggy's Avatar
    Jan 2008
    175
    Quote Originally Posted by susa
    The acid injection keeps the builtup to minimum and should like a good maitnenance pratice.
    Next time I check mine I will take a few pictures and maube a movie.
