Thread: Is it worth it to drain my pool?
    people,
    Tired. Winter time, even in FL. Is it common to drain the whole pool then fill in April to use again? Figure, 6 months will save me lots. Feedback appreciated.
    Pip
    16,000 gal in ground, marcite. FL.
    Re: Is it worth it to drain my ppool?
    No, it isn't usually a good idea to drain the pool completely. If you have a vinyl liner or fiberglass pool or a high water table (common in FL) you risk significant damage to the pool. It is also wasteful of water.
    You can "winterize" the pool, cover it up and stop running the pump, to save money, especially if the water temperature is below 60 degrees.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    If it's one of the Intex type temporary pools it's okay to take down and store. You might want to put your specifications in your signature line.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Re: Is it worth it to drain my pool?
    Thnaks, guys. Sorry for delay. I updated my signature too. Guess I wont dump my water. Yes, its wasteful, but a poool is a waste to begin with, one can argue. Waste the water, save the electrical power to maintain for 6 months, I figure. One chooses what to waste..........
    Hopefully, the pool wont develop too much algae during winter, I hope.
    Thanks.
    Oct 2011
    Frisco, TX
    47
    Water. Water. Some states are running out. You are in fl, nevermind.
    Size 13,000 gal | Filtration Jandy DE 60 | Sanitation PLC1400 SWG, Rainbow 320 | Placement in-ground (IG) | Coping Tennessee Crab Orchard
    Finish pebble smooth Tahoe Blue | Pumps Intelliflo VS+SVRS 3.0HP main | Lighting Jandy LED Spa/Pool
    Location Frisco TX US
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    During the winter algae doesn't normally grow as fast. The sun is at a lower angle and the temps are cooler, even if not cold in FL. You can usually cut back on the amount of time you run your filter and on the amount of chemicals you use. I'm sure there are others here that could give good advice for how they run their pools in the FL winter.
    Dan D
