Thread: adding chlorine off season
    Mar 2009
    Galveston, Tx
    16
    After September my pool is only used when I heat it for a few days a couple of times during the winer. My question is, do I need to keep the chlorine levels the same during these prolonged periods of not using the pool.
    23 K Gal
    DE
    IG
    gunite
    2 Hp Pentair pump
    Filter: DE Nautilis FNS 60
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: adding chlorine off season
    Yes you do, in order to prevent algae from growing. When the water temp gets colder, the chlorine usage should drop considerably if the pool is covered or if the sun is not hitting the pool for as long. While colder temperatures slow down algae growth rates, they also slow down chlorine kill rates so you still need to maintain roughly the same chlorine level if you want to ensure there is no algae growth (technically it might be less, but it's easier and safer just to keep it the same).
