Thread: pond pump for inground pool
    my 6 yr old hayward is on its last legs . i have a buddy who builds ponds and recommended a pond pump, specifically a Performance Pro Artesian. any thoughts pro and con?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: pond pump for inground pool
    Not electrically certified for humans in the water while it is powered.
    May 2009
    Youngsville NC
    395
    A pond is not quite the same thing as a pool. While I would use a pool pump in a pond, I'm not quite so sure about vice versa...
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    You will have to start calling your pool a pond.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    that settles that. cement pond
    vinyl pond
    pool pump it is thanks guys.
