Page 1 of 6 1234 ... LastLast
Results 1 to 20 of 113
Thread: Finally ready to go to work on my green swamp!
    Guest
    I was finally able to run the pump (circulate) for an hour this morning and get my first testing done with my new Taylor K-2006 kit. Water is very, very green with a ton of algae Below are some pics of my equipment:
    Here are my test results:
    FC 0
    CC 0
    PH 7.2
    TA 50
    CH 120
    CYA -30
    I have memorized pool school so I know what I need to do, but this is my first pool so I welcome any suggestions - these are my initial questions:
    I did the CC test twice - is it possible that there is no CC in the pool?
    The 30ppm is the lowest that the Taylor kit goes - do I just add 20ppm of CYA to make sure that I don;t put too much in?
    Do I need to do anything to raise the TA?
    Do I bother with the PH as its only .3ppm on the low side?
    Can someone please explain to me what the booster pump does and how it works? Also, in my control panel there are two on/off switched above the two timers - I guess the second one is for the booster pump. Should I run the booster when I'm running the other pump? Will the booster increase water flow and help clear the pool faster?
    Thanks for the help
    30,424
    Re: Finally ready to go to work on my green swamp!
    1. Shock the pool by following the procedure outlined in Pool School.
    2. Disregard CC's for now
    Disregard TA for now
    Your pH is fine. leave it where it is
    3. Your CYA info is just a little confusing....Do you have 30 CYA right now or do you have zero? 30 CYA is a fine place to start the shock process.
    Guest
    The lowest CYA readiing on the Taylor test kit that I have is 30ppm. My CYA is lower than that because with the test compartment filled to the top I can still see the black dot on the bottom of the compartment....
    30,424
    I understand, now. I would call that ) CYA and add enough into the pool to get to 20-30ppm while you are in the shock process. You will add more later but 20-30 is about perfect for shocking.
    Guest
    Dave,
    Thanks! You meant 0 CYA, right? So I should add around 3lbs to bring me into that 20-30ppm range?
    What do I need to know about this booster pump?
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Yes, add the CYA now.
    I'm not sure about the booster pump. Hopefully someone will know.
    Bump :~}
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    30,424
    Sorry about the typos but you interpreted it correctly.
    The booster pump is there for the purpose of operating a pressure-side cleaner like the Polaris 280, for example.
    It's only function is to increase pressure to the cleaner when you are cleaning the pool and serves no other purpose.
    Guest
    Hmm.... so the second timer in the control panel would start booster pump which would activate the auto cleaner? (assuming it was hooked up and in the pool)
    People leave their bots in there and set the timer for when they want to bot to clean and just let it go?
    30,424
    I have no idea how the second timer is wired. Do the wires go to the booster pump?
    Guest
    Another question:
    If I put CYA in a sock in front of a return can I still backwash the filter regularly during the shocking process?
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by wkener2
    Another question:
    Yes.
    You're done SLAMing when:
    htownjeeper's Avatar
    Aug 2011
    Nassau Bay, TX
    199
    Your setup with two timers looks almost exactly like mine. Turn on your booster pump and see if the jet in the center of the pool gets extra pressure shooting out of it. If so, and you're not using and auto cleaner right now, just turn off that timer and unscrew the little arrow things that trip the timer. The booster pump really serves no other purpose but for the auto cleaner. Well, unless you just want to get a good back massage while in the pool because if yours is like mine, it puts out some serious pressure.
    22,000 inground Fiberglass
    DE Filter Pentair FNSP 48
    Century Centurion 1.0 HP 1.25 S.F. 3450 RPM
    Guest
    Started shocking this morning and took these pics before I started:
    Sep 2009
    Greentown, IN
    914
    Looks like you've got your work cut out for you. Hang in there and give it some work and patience and you'll soon have some gorgeous water!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Nov 2010
    South Central Kentucky
    283
    Work on getting those solids out with a net. Eating all of that up with just chlorine could take a long time. Stick with the process, it works!!!
    15x32 vinyl liner, 14,400 gal, 1.4hp Centurion pump, 3/4 hp booster pump, Hayward Pro Series S244T Sand Filter, Hayward H200 heater (digital readout)
    Aqua Rite Electronic Chlorine Generator, Hayward Phantom cleaner, TF 100 test kit
    Pool School, Pool Calculator
    Guest
    Making progress, but algae is kicking my but pretty good! I have not been able to test every half hour and therefore have not been able to keep the shock level high enough for long enough Its after dark now, and I brought the pool back up to shock level a half hour ago and am going to test now. Here are pics from mid-day:
    Guest
    Just did FC test: FC dropped from 13ppm to 9ppm in a half hour! I brought it back up to shock level and will re-test in 30 minutes...
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    It looks LOADS better! You're doing great. Lovin the images.
    If you can keep it up every half hour or so tonight till late I bet you'll see something that pleases you tomorrow morning :~}
    Bump the last dose up a few ppm (base it on what you see it lose during tonight's testing) while you sleep so there's a little extra to keep things moving overnight.
    Guest
    This time FC tested at 10.5ppm! Will bring back to shock level and check in another 30 minutes....
  20. Back To Top    #20
    Guest
    But CC is now 2ppm... looks like we are getting somewhere!
