Results 1 to 7 of 7
Thread: New Sand for my Sand Filter
    Sorry if there is already a thread on this. Going to need new sand this fall when I close up. What do I need to know before I dive into this? Any easy way to do this? I will appreciate any lessons learned. Thanks.
    Trenton, IL (St. Louis Area)
    TF-100 test kit, 18,000 gallon, 18x33 oval Johnny Weismuller, AG, Jacuzzi Lazer sand filter, AquaTrol SWG, 1.5 HP Pentair pump that runs constantly.
    Aug 2010
    Dallas, TX
    4,052
    Re: New Sand for my Sand Filter
    Why do you think you need new sand?
    The current sand has been in there for 6+ years and my pressure is running a little high (29 psi). Maybe it just needs a good cleaning.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Not much evidence for sand needing replacing. Take a look at this post by teapot: http://www.troublefreepool.com/sand-...9.html#p247326. If anything, maybe you sand is channeled, you could try this: http://www.troublefreepool.com/my-sa...26.html#p60821
    30,408
    My first thought is you need to backwash. If that doesn't get your pressure below 20psi, your gauge may be faulty. Do you recall what your normal psi has been over the years?
    Jun 2011
    Cape Girardeau, Mo
    125
    I don't think sand ever wears out it gets dirty but nothing a good cleaning will not take care of or maybe it is channeled i would take it apart and give it a good cleaning ..and as Dave pointed out could be a bad gauge they are cheap.
    Steve Frakes
    15' X 48'' Intex Metal Frame
    Intex Sand Filter 16'' 2650 GPH
    Taylor K-2006 Test Kit
    BBB and Borated
    I have had to add a lot of stabilizer through the skimmer this summer so maybe all it needs is a good cleaning. I will try the hose in the sand and see what floats out. If that does not work I will try the acid cleaner since I had a lot of scale fall off my SWG when I cleaned it last week (see photos on my other post). I was wondering how sand could "go bad" but I'm sure the pool store will sell you new sand at a "reasonable" rate.
