Thread: Intermatic timer gears moving but clock dial not
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    On an Intermatic timer, if the motor gears appear to be moving but the clock dial is not, what is most likely the problem?
    Intermatic T4003RT3
    Thanks.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    22,543
    Re: Intermatic timer gears moving but clock dial not
    Most likely a gear is slipping on a shaft somewhere.
