Thread: Intermatic pe153 timers.
    I need some help, any of you ever installed a pe153 intermatic digital timer? having some trouble, I have 240v hooked up to 1&2, where do i hook up the pump and booster pump?
    18' Summer Escapes ProSeries - 7600gal - Hayward 1hp pump w/18" sand filter - AquaTrol SWG -
    22,542
    Re: Intermatic pe153 timers.
    Assuming you're using mode 3, and your pumps are 240v, you need a jumper from 2 to 3 and from 3 to 7. You'll hook one leg of the pumps to terminal 1 and the other leg of the main pump to terminal 4 and the other leg of the cleaner pump to terminal 8.
    Like This!
    [attachment=0:3mobcehw]Pe153.PNG[/attachment:3mobcehw]
