Results 1 to 7 of 7
Thread: main drain
    main drain
    Hi I was wondering if the main drain in a pool needs to be on ? I dont think it was on last year, this year when the pool guy opened it is on. This is my 2nd year owning a pool so I'm still new to it.
    Its an inground pool.
    Thanks.
    Mike
    ___________________________
    38,000 Gallon Gunite, 2 NorthStar Pumps, 1 booster pump, cartridge filter, 400k BTU Gas Heater
    Pro Logic PS-8, Sense and Dispense, Stenner acid pump, Aqua Pod, waterfall, slide, spa
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: main drain
    I have some flow through mine. I think it helps keep the water mixed. Otherwise, the return jets are only about a foot below the skimmer, so the top of the pool gets filtered, but what about below? I also have noticed that I don't have that layer of colder water down at the bottom like many other pools I'm swam in.
    It's also nice to be able to brush stray bits of debris at the drain and have them get sucked away. No need to wrestle the vacuum hose.
    Jul 2010
    GTA, Ontario, Canada
    16
    Re: main drain
    How does one turn it on?? We are in the opposite situation -- our first year of pool ownership the drain was on and it isn't anymore. There is no suction through the main drain on the floor of the deep end.
    Canadian Pool newbie!
    Kidney-shaped 16x32, in-ground, SWG, vinyl liner, 20,000 gal [approx. 75,000 L]
    Hayward "Super Pump" 1 HP; Hayward Sand Filter (flow rate 200 L/min [53 G/min]); Zodiac Clearwater LM2 SWG; Jandy heater
    Full sun from 7 am to 7 pm, no trees
    Three young kids aged 5 and under ~~ heavy bather "loads" and lotsa coaching about peeing in the TOILET!
    Re: main drain
    thanks.
    As for turning it on. There should be a lever for it near your filter.
    Mike
    Re: main drain
    There are different ways the main drain can be installed. Ideally it has a separate pipe going to the equipment pad and there is a valve on the pad that allows you to control where water is drawn from. Some builders leave out the valve. Other builders plumb the main drain to a second hole in the bottom of one of the skimmers. If you have that there is a special fitting you can get that allows you to force the skimmer to draw some of it's water from the main drain pipe.
    Jul 2010
    16
    Re: main drain
    Thanks again. We don't have a separate valve, so I assume ours is linked to one of the skimmer holes. If I recall correctly, the main drain worked one season, then we had a pool store winterize and close our pool for the season. My husband opened the pool the next spring, and the drain stopped pulling water. Was hubby supposed to do something to "open" that drain again? I don't recall seeing anything in the hole, but I'm at work at the moment. Today after work I'll take a closer look...
    Re: main drain
    If you have a skimmer with two holes in the bottom, there is a special part that proably looks something like one of these:
    that goes in the bottom of the skimmer. Perhaps he forgot to reinstall that part.
