Results 1 to 9 of 9
Thread: Pool Filter Drain Plug
    Mountain View, Arkansas
    64
    Hello everyone. I have a Hayward sand filter. I am not sure of the model and I am trying to find a drain plug for it. Are all hayward drain plugs similar? I misplaced mine and not sure how to proceed.
    Mountain View, Arkansas, 23,000 gallon in-ground concrete pool with a 24-in Hayward Pro-Series Sand Filter with side-mount. Chlorinator is attached but only use occasionally and a 1 hp pump.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Pool Filter Drain Plug
    A garden hose (3/4") end plug/ cap works on most of the Hayward filters I've played with.
    Luv& Luk
    -Ted
    64
    My filter may not be a hayward then. I moved into the house 2 years ago and this is the shape the filter was in. A 3/4 inch hose size end is to small. Hope the pics help someone identify it.[attachment=0:2yyuu5t9]Pool Filter 1 (480x640).jpg[/attachment:2yyuu5t9]
    64
    Here is a closer pic of the drain[attachment=0:3dvss2dz]Pool filter drain 1.jpg[/attachment:3dvss2dz]
    64
    I hope someone can help. Just received my TF-100 test kit yesterday and am ready to start getting the pool running. Losing this drain cap has definitely put a damper on things. Thanks to those that can help
    Mar 2009
    Charlotte, NC
    539
    Looks alot like my Pentair Sanddollar, manual attached.
    Others here have more experience than me.
    You can go to the poolstore & tell em the 3/4" is too small & buy svereal other sizes then return the wrong ones, take the photo w you.
    Attached Files Attached Files
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Mar 2009
    Charlotte, NC
    539
    And on a piece of paper outline the circumference w a pencil & that to the store? Buy a few sizes if in doubt & return the wrong sizes
    64
    Thanks everyone. I will measure and go from there. Trying to order one online. Just making sure I get the right one.
    64
    I measured it 1 3/4. Ugh. And I have no pool stores within 50 miles. Guess ill be making a trip
