Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: Do I need to shock
    Do I need to shock
    Just did my latest pool readings..
    FC 3.0
    CC 1.5
    PH 7.4
    TA 100
    CH 250
    CYA 50
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    Re: Do I need to shock
    Sorry CYA is 50...
    Bel Air, MD 21015
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Yep. CC should be .5 or less.
    If I shock tonight will I be able to swim tomorrow?
    Bel Air, MD 21015
    I have no algae...
    Bel Air, MD 21015
    CC at 1.5 might go away in a few hours, or it might take another day or two, it is unpredictable. The sooner you start, the sooner you will be rid of it
    Aug 2010
    Dallas, TX
    4,052
    Quote Originally Posted by precator
    I have no algae...
    ...that you can see! Either you have a bottom full of leaves or you have some algae hiding somewhere!
    With cya at 50 my shock level is 20 correct?
    Bel Air, MD 21015
    Aug 2010
    Dallas, TX
    4,052
    16 according to poolcalculator.com but I usually aim for a couple of points over recommended at first and then try to hold shock level afterward.
    So now I wait an hour, test, and if say my FC is at 12 and my CC is still over .5, I would calculate how much Chlorine I would need to get to 16 FC correct? And repeat this every hour if possible?
    Bel Air, MD 21015
    Also, can I vacuum while at shock levels?
    Bel Air, MD 21015
    now I am seeing a bunch of white stuff floating on the top of the pool after shocking.. Anyone know what this is?
    Bel Air, MD 21015
    Apr 2010
    East Texas
    9,626
    Quite possibly dead algae.
    looks like it is slowly clearing up. Will my filter eventually get all this dead algae if thats what it is? I have a DE filter..
    Bel Air, MD 21015
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Yes it will You'll need to turn the water over a few times, but DE is really shines when it comes to clearing up algae.
    So by morning it should be gone correct.. Also does this mean I am done shocking since algae is dying?
    Bel Air, MD 21015
    Apr 2010
    East Texas
    9,626
    See pool school for the criteria for being through shocking.
    May 2011
    lebanon tn
    370
    Yes you can vacuum while at shock levels... and swim, as long as you're not excessively high above the shock values!
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    This is the picture of the white stuff. I still have CC of about 1.5 now.. I just re-shocked with 7 jugs of bleach to be at the 20 shock level..
    Bel Air, MD 21015
  20. Back To Top    #20
    Closer pic of buildup on sides of pool..
    Bel Air, MD 21015
