Thread: Scroll vs twin piston
    Hi,
    Summit still uses both these types of compressers. Is there a difference in terms of reliabiliy?
    Thanks
    Cement 12'x30', in the neighborhood of 50 years old. Restored, 1.5"plumbing, 1hp super pump 2, Hayward swim clear cartridge filter, Summit2.5t heater,Hayward SWG t-9 cell, Nexxus Blanco lights, pentair bermuda gunite skimmer.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Scroll vs twin piston
    For this type of application scroll compressors are the way to go, the service life on scroll compressors has historically been worse than hermetic piston units, having said that a lot of money has been spent improving scroll designs, and today I would consider most of them on par or better than piston style compressors in this size range. Piston units still win on larger compressors (above 5 - 10HP) and those that need low temperature operation.
    Ike
    so if your saying there on par at this size, Im assuming that a two year old unit with a piston compressor and a titanium exchanger would be good for a few more years before servicing.
    thanks for your help
