Results 1 to 8 of 8
Thread: Pool Pole Cam Glue?
    Pool Pole Cam Glue?
    Any idea on a household glue that would hold the plastic cam to the aluminum pole? Mine had broken free and needs to be reset.
    17k in-ground, Pebble Sheen finish (Blue Granite), Solar, two skimmers, split drain.
    IntelliPro VS-3050, IntelliChlor IC40, EasyTouch 4 control system, Easy Touch wired indoor panel.
    300 CuFt cartridge filter. Polaris 380 with booster pump. Two IntelliBrite 5G lights.
    TF100 test kit.
    Re: Pool Pole Cam Glue?
    Either Household Goop or Plumbers Goop should work. There are several others, but those are the ones I remember at the moment.
    JoshU's Avatar
    New Orleans, LA
    543
    Gorilla glue would probably do it too.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Waterproof epoxy?
    22,553
    If you use Gorilla (or other expanding) glue be mindful of the expansion as it could break the plastic collar.
    SW Georgia
    300
    I used two part epoxy on mine.
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    I just drill a hole through the pole at the correct length and use a 1/4-20 x 1.5 inch stainless steel bolt and wing-nut to secure the pole.
    Support the site
    I went with Plumber's Goop, easily obtained at Home Depot for under $5. It is still curing, but the initial setup is great and I am sure this will work out fine.
    Thanks all, especially Jason.
    Ed
    TF100 test kit.
