Results 1 to 9 of 9
Thread: Copper Ionization?
    Mar 2010
    Huntington, WV
    150
    Copper Ionization?
    What is it? Is it bad for your AGP? I see where the newer models of the Intex SWGs have it, but the older ones do not and those are hard to find. Thanks.
    24' AGP
    Hayward Power-Flo LX 1.5hp pump
    Hayward Pro Series S180T 150lb sand filter
    Intex 54601EG Krystal Clear SWG
    Diver Dave pool cleaner
    22,544
    Re: Copper Ionization?
    It's bad in the sense that it causes staining. The best thing to do is unplug the ionizer and just run the SWCG. Intex added it to thier units and also reduced the output of them.
    Mar 2010
    Huntington, WV
    150
    Ok, so you can just unplug the copper part of the SWG? If that is so, it makes me feel a little easier about buying one this spring. Thanks.
    24' AGP
    Yes, you can simply disconnect the wire running to the copper ionizer.
    Sep 2009
    tennessee
    17
    how much less are newer models producing (chlorine) have 2yr old model happy with this item, wondering about replacement?
    15k, ig ,vinyle ,kitbuilt, 1hp hayward, 24 hayward sand, 2-intex swg`s, manual cleaning, leslies k2006 test kit,14x28, fiberglass steps
    Jul 2009
    London and France
    574
    Quote Originally Posted by Jeff74
    As it is an above ground pool (vinyl) and your swg will already have it so your not buying anything extra and providing you can test and adjust the copper level independently why not use it, you will have less to worry about algae wise, it can also help with biofilm build up, it takes some of the workload away from your chlorine thus will make your salt cell last longer and you can run with lower chlorine levels.
    If your pool was concrete/plaster/tile I would say absolutely disconnect it.
    Going to put my flack jacket and tin hat on now
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Quote Originally Posted by taintn
    The newer model Intex produces 12 grams/hour, the older ones are 24 grams/hour. I had to settle for the newer model when I got mine The good thing about it is that the timer keeps it's settings if you have a power outage or need to unplug it for some reason. As for the copper issue with these, I cut the copper bars off the plug because they looked like they could cause a flow restriction.
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by teapot
    LOL
    Jeff,
    If you have blonde haired family members or pets with white hair, disconnect the wire. if you don't disconnect the wire, just be sure to keep the PH in the recommended range to avoid staining.... while rarer, copper staining can occur on vinyl pools too.
    Nina Li's Avatar
    Jun 2012
    Tampa, Florida
    98
    Yes that happened to me, staining in a few spots, but for some reason, when I lowered the usage from 2 to 1 hr a day for the swg. with my filter (8 hr / 12 hrs a day), the staining went away. I have a 16' x 48" size ag ultra frame pool...I guess the copper was reabsorbed? Not too sure why, but it DID go away after I changed the swg settings and that's good news for me!
