Thread: How to check/change fuse in Intellichor Power Box
    Oct 2010
    Pensacola, FL
    67
    I have an Intellichor 40 salt generator and no power to the cell. Does anyone know how to check and change the fuse which is located on the bottom of the power box?
    Bill Moyer
    CWO4 USN (Ret)
    Pensacola, FL
    10k gallon 12x24 in ground pool built 2008, vinyl, Pentair Intellichlor IC40, Pentair Intelliflo v/s pump, Hayward sand filter. Using the BBB method.
    susa's Avatar
    Oct 2010
    Deep South
    578
    Re: How to check/change fuse in Intellichor Power Box
    you mean chlorine generator ?
    see this post
    do you have a multitester tool ?
    if yes, does the unit receive power from the breaker ?
    from the Pentair Q & A:
    Common Problems and Solutions
    1. “PWR” light not on or Red
    Check to make sure either 120VAC or 240 VAC input power is connected to the
    proper wire connections on the Power Center. Verify input voltage with a volt meter.
    If there is input power, the fuse may have blown. The Intellichlor is protected by a 10
    amp fuse located on the bottom of the Power Center enclosure, next to the cell quick
    connect cord receptacle. Unscrew the fuse holder, check fuse and replace as
    necessary.
    turn off the breaker before service.
    Oct 2010
    Pensacola, FL
    67
    Yes, this is a chlorine generator. There is ac power coming into the box, but none from the transformer. Does the fuse unscrew from outside bottom of box, or do I remove the fuse from the inside. Also, there is no green LED light INSIDE the box, which should be on. Thanks
    Bill Moyer
    CWO4 USN (Ret)
    Pensacola, FL
    Dec 2008
    82
    it unscrews from the outside bottom.
