Page 1 of 4 1234 LastLast
Results 1 to 20 of 76
Thread: Under construction in texas - water in it finally!
    Aug 2010
    Austin, TX
    200
    Hi everyone, I'm new here. Been lurking for a while learning about pools. This is a wonderful forum, I appreciate having such a source.
    Our pool is in flight. I thought I would share some photos with all of you as it progresses. Please ask questions, tell me we're crazy, etc.
    Design:
    (Umbrellas will be in holes, not stands)
    Construction:
    38K Gallons IG, Intelliflow VS-SVRS, 30GPM 24/7, 72sqft DE Filter, Spectralight UV, Jandy C1900 driving Liquid Chlorine and Acid (toys, I know..), Jandy LXi gas heater, Aquacal SQ175 Heatpump, Riverflow Competition swimmer, Jandy automation, Touch and iAqualink, Pebblesheen | The Build
    Aug 2010
    Austin, TX
    200
    Re: Under construction in texas
    Dec 2009
    Central Massachusetts
    2,690
    My god you have nothing but ledge under your yard. And shallow too. That must have cost a fortune to hammer all that out.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Jun 2010
    San Antonio
    424
    Rather typical of parts of Texas including my back yard. That's why I have an above ground. Shakenback you have a beautiful pool and backyard oasis.
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    Aug 2010
    Austin, TX
    200
    Quote Originally Posted by bk406
    Fill and cement would have been more I'm told. It was fixed bid, so did not end up too bad. 2 weeks of excavation, it must have been brutal for the operator in 100+ degree texas heat.
    Quote Originally Posted by Txmat
    Thanks. I was getting tired of the lawn dying every year - Austin is pretty strict on water usage.
    30,432
    Hey, Shakenbake,
    Welcome to the forum. What a great pictorial. I am completely impressed with your pool builder. It looks like his folks have done a great job to this point. That will be one georgeous pool.
    I'll be the first to admit my ignorance. I do not understand the function of the three large rectangular devices (one with grillework) in the deepend. Help!!
    VERY, VERY well thought out pool. Can't wait to see more progress!! Thanks for sharing!
    Aug 2007
    near the swamp
    806
    I think those are the suction grates for the water features.
    Butterfly's Avatar
    South Carolina
    10,045
    Are you crazy? Heck no!
    I am a big fan of multiple umbrellas and your pics look amazing!
    Can't wait to see the finished product!
    Keep us updated
    You're done SLAMing when:
    Aug 2010
    Austin, TX
    200
    Thanks everyone for the kind comments!
    Makes me feel a lot better - I don't have a frame of reference for judging the construction quality. They are highly recommended in Austin, and we've had great luck - but I'm kind of a control freak, so I've been a bit nervous not having the experience to run the project myself.
    The 3 large grates are for a Riverflow swimming pump - basically a variable speed 10HP pump that pushes a stream of water into the pool that simulates swimming continuously. My wife is really into swimming for exercise, and I plan to learn too. The two bottom grates (one missing a grate) are the intakes, and center at the top is the jet/return.
    It's really hard to be patient!
    Apr 2010
    Austin, TX
    49
    Looks great. Maybe a bit crazy, but it'll be a ton of fun. Good luck.
    We just completed our pool in Austin, and have had our first week of swimming! We went with Ocean Quest Pools, no complaints. Who is doing your pool? Did the city make you plant other trees because you cut some down, or are you outside the city limits?
    Kelly
    10K IG, Gunite with Wet Edge "Midnight Ocean" pebble surface, with spa, tanning shelf, and fountain. Pentair Intellibrite LED pool and spa lights. Rola-Chem chlorine pump (and tank), Pentair DE "Quad 80" cartridge filter, 400K BTU gas heater, VF Whisperflo, and Legend Pressure Side Cleaner with Pentair booster pump. Using TFTestKit.
    Aug 2010
    Austin, TX
    200
    Quote Originally Posted by kellyj
    Kelly
    Pool Pro - they've been very solid so far. We're likely to be ice skating on this thing before we get to swim in it.
    Tree-wise, I guess we're outside city limits - though the homeowners association "architectural committee", chaired by the neighbor directly behind us, has asked us to plant 2-3 big trees.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Man I bet your neighbors were glad when the jackhammerring was over.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Pisces's Avatar
    Jun 2008
    League City, Texas
    273
    I'm in LOVE!! Beautiful design!! You'll need all the umbrella shade you can get for our Texas sun. Please let us know the tile, coping, etc. materials you're using asap...I'm so curious (I do see some flagstone, etc. on the drawing). Will be watching the rest of the build with bated breath. Congrats!
    7,000 gal. IG gunite, SWG, PebbleSheen interior finish-Aqua Blue, 8' vanishing edge raised 16-jet overspill spa, 2 12" waterfalls, tan shelf with bubbler.
    Pentair equipment: Easy Touch 8, Intellichlor IC-40, Intelliflo VF 3050, 2.5 hp Whisperflo spa pump, 1 hp Whisperflo water feature pump, Quad 100 DE filter, Master Temp 400 heater, Legend Platinum Cleaner (3/4 hp pump). Autofill, TF-100 Test Kit w/salt and borate strips.
    Pisces Pool Build
    Aug 2010
    Austin, TX
    200
    Quote Originally Posted by Lershac
    We felt awful, cookies and margs for everyone when this is done.
    Quote Originally Posted by Pisces
    Thanks! We're getting close on the materials, it's more complicated than I expected
    Aug 2010
    New Caney, TX 77357
    184
    That's an amazing setup, looking forward to pics of the finished project.
    20K gal, inground with attached spa, pebblefina plaster (bella blue), flagstone coping, moss rock waterfall, Sundek - Indian wheat, (2) Jandy PHPM2.0 (filter pump and waterfall), Jandy DEV60 DE filter, Polaris 280 pool cleaner, Polaris Halcyon PB4-60Q booster pump, Polaris 1.5 HP Air Blower, (2) Jandy WaterColors LED lights, Jandy LXI400P Heater, Jandy AquaPure PLC1400 SWG, Jandy AquaLink RS PureLink Controller and PDA.
    Aug 2010
    New Caney, TX 77357
    184
    Quote Originally Posted by Partyboat123
    Very few I have seen as like as yours design. That's simply wonderful. Hope you will not late showing us the full project.
    Yoda, is that you? :P
    Wow this is definitely going to be a great looking pool.
    25x25x16 L shaped concrete, 4' to 6', 21,000 gal, PLP4 - Pro Logic System Control & Aqua Logic Salt Chlorine Cell, Hayward TriStar 1 HP, 24" Sand Filter, SunHeater Solar Heating System, ColorLogic Light, Jandy deck jets.
    Quote Originally Posted by shakenbake
    Did you tell him that he can come over and clean up the mess those trees put into the pool then? Not to mention the trees roots can get into your piping over time...pop your decking...all kinds of stuff just because he lives behind you and missed a tree or two.
    Big trees are not cheap either. I would tell him where to go, but that is just me.
    Never been a fan of HOA's myself (does it show? hehe), but that is just silly to ask you to mess up what you just put in.
    25k gal vinyl AquaRite T-15
    Aug 2010
    Austin, TX
    200
    Quote Originally Posted by danbutter
    I don't have a problem with the concept of an HOA, just the people the jobs attract.
    ...I think we'll end up with one new tree for shade. Done.
  20. Back To Top    #20
    Aug 2010
    New Caney, TX 77357
    184
    shakenbake - any updates?
