Thread: salt water plus weekly boost.
    I got two bags of this stuff. Is there any reason for it. Says to add it weekly. I'm figuring some more bs
    Intex Easy set 18x48 pool
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    Dec 2009
    Central Massachusetts
    2,690
    Re: salt water plus weekly boost.
    I googled it, but nothing came up. What is the exact name on the bag and who makes it?
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    aqua chem pool salt plus
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    They don't appear to say exactly what it contains, but with all the features listed it must contain several different things. As a general rule I prefer products that contain a single chemical and say what it is. That way you have more control and can add the chemicals you actually need and avoid the others.
    i see no reason for it. do you add anything weekly. I just add what is needed daily to adjust ph and fc. generally it was just bleach when i was non swg.
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
