Thread: Dichlor and CYA
    guamguy's Avatar
    Feb 2010
    Guam, USA
    Dichlor and CYA
    I've been using some dichlor left by the previous owners to adjust my CYA. Should I wait about a week to test, or does the CYA dissolve into the water faster with dichlor than it does with granular CYA?
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool!
    Mar 2007
    San Rafael, CA USA
    Re: Dichlor and CYA
    It should dissolve much faster, essentially giving you CYA at the same time it gives you FC.
